Brands
Brands
Rigid Industries Radiance 10 Inch Light Bar (choose color)
The all-new Rigid Industries’ Radiance is the perfect solution for those who want Rigid’s legendary quality at a level everyone can attain. The Radiance is built with the same high-grade aluminum alloy housing as our legendary E-Series, but that’s where the visual similarities end. Inside, the Rigid Industries’ Radiance is feature-packed, with a black exposed printed circuit board, optimized forward projecting Broad Spot optics which combine the attributes of a spot and flood beam pattern, and back-lighting available in white, amber, red, blue and green. Large back-lit Rigid branding plates further add to the unique look of the Radiance. The Rigid Industries’ Radiance is for the customer who wants a truly custom look that only Rigid can provide. Available in 10” – 50” lengths, the Rigid Industries‘ Radiance is the perfect entry into Rigid Industries’ performance LED lighting.
- 9-15 V DC
- High-Grade Aluminum Alloy Housing and Heatsink
- Black Powder Coated Mounting Brackets
- Dedicated Wire to run Back-Lighting without Primary LEDs
- IP68 Compliant – Dust / Water Ingress
- High Impact Polycarbonate Lens
- Complete Multi-Switch Wiring Harness Available (sold separately)
- GORE® Pressure Equalizing Vent
Specifications
- Watts: 61.8
- Amp Draw: 4.42
- LED's: 6
- Raw Lumens: 3528
- Lux @ 10m: 906
- Beam Distance: 264 m
- Peak Beam Intensity: 86520 cd
