Rigid Industries Dually - Spot - Single
$104.49
$104.49
20121
  • 10° Spot Pattern
Specifications
  • Watts: 15.8
  • Amp Draw: 1.1
  • LED's: 4
  • Raw Lumens: 1568
  • Lux @ 10m: 646
  • Peak Beam Intensity: 64600 cd
