Rigid Industries Dually - Spot - Single Flush Mount
$123.49
$123.49
21121
Flush Mount - This particular model is specifically designed to be recessed into a truck bumper, a utility bed, the hull of a boat, or any application where you need the light to look clean and be out of the way. Once installed, the light is only 1/4" tall, which means you can have all the benefits of our surface mount lights in an OEM quality, flush installation.
  • 10° Spot Pattern
Specifications
  • Watts: 15.8
  • Amp Draw: 1.1
  • LED's: 4
  • Raw Lumens: 1568
  • Lux @ 10m: 646
  • Peak Beam Intensity: 64600 cd
