Rigid Industries Dually - Spot - Pair Flush Mount
$223.24
$223.24
21221
Flush Mount - This particular model is specifically designed to be recessed into a truck bumper, a utility bed, the hull of a boat, or any application where you need the light to look clean and be out of the way. Once installed, the light is only 1/4" tall, which means you can have all the benefits of our surface mount lights in an OEM quality, flush installation.
  • 10° Spot Pattern
