Rigid Industries Dually - Spot - Pair Amber LED
$189.99
$189.99
20222
Amber LED's - This model features amber LED's. Amber lighting is often used to improve visibility in harsh elements. The glare from blue light is very difficult for the human eye to process. By removing blue from the light spectrum, we reduce the glare from snow, rain, fog, and dust which results in better visibility.
  • 10° Spot Pattern
Specifications
  • LED's: 4
