Rigid Industries Dually - Flood - Pair Flush Mount Amber LED
$223.24
$223.24
21212
Flush Mount - This particular model is specifically designed to be recessed into a truck bumper, a utility bed, the hull of a boat, or any application where you need the light to look clean and be out of the way. Once installed, the light is only 1/4" tall, which means you can have all the benefits of our surface mount lights in an OEM quality, flush installation.
Amber LED's - This model features amber LED's. Amber lighting is often used to improve visibility in harsh elements. The glare from blue light is very difficult for the human eye to process. By removing blue from the light spectrum, we reduce the glare from snow, rain, fog, and dust which results in better visibility.
  • 20° Flood Pattern
