Rigid Industries Dually - Diffused - Single
$104.49
$104.49
20151
Diffusion Lens - Perfect for scene or area lighting, our diffusion lens was specifically engineered to project light at a 60º flood pattern. Combine that with our patented optics and you have the best LED flood light in the industry. Like our standard lens, the diffusion lens is made from optically clear, unbreakable polycarbonate plastic.
  • 60° Diffused Pattern
Specifications
  • Watts: 15.8
  • Amp Draw: 1.1
  • LED's: 4
  • Raw Lumens: 1568
  • Lux @ 10m: 11
  • Peak Beam Intensity: 1100 cd
