Rigid Industries Dually - Diffused - Single Flush Mount
$123.49
$123.49
21151
Flush Mount - This particular model is specifically designed to be recessed into a truck bumper, a utility bed, the hull of a boat, or any application where you need the light to look clean and be out of the way. Once installed, the light is only 1/4" tall, which means you can have all the benefits of our surface mount lights in an OEM quality, flush installation.
Diffusion Lens - Perfect for scene or area lighting, our diffusion lens was specifically engineered to project light at a 60º flood pattern. Combine that with our patented optics and you have the best LED flood light in the industry. Like our standard lens, the diffusion lens is made from optically clear, unbreakable polycarbonate plastic.
  • 60° Diffused Pattern
Specifications
  • Watts: 15.8
  • Amp Draw: 1.1
  • LED's: 4
  • Raw Lumens: 1568
  • Lux @ 10m: 11
  • Peak Beam Intensity: 1100 cd
